andyinatl
Apr 27, 2020Tutor
My Orbi RBR20 / AC2200 bounces connection multiple times a day
Orbi AC2200 + 1 Satellite Firmware (on both) = V2.3.5.30 currently (was V2.3.5.26) Router = Arris SURFboard SB6141 Internet provider = Comcast At multiple times of the day, the Orbi RBR20 / AC...
Apr 28, 2020Guru - Experienced User
I recommend you contact NG support for additional help and information regarding this. Ask about an RMA.
andyinatl
May 15, 2020Tutor
FURRYe38 wrote:I recommend you contact NG support for additional help and information regarding this. Ask about an RMA.
https://www.netgear.com/support/#
Regretfully, I ended up returning the product to Costco and purchasiing a competitor's product of which I am having no problem.
Thank you FURRYe38 for your attempt to assist.
- FURRYe38May 15, 2020Guru - Experienced User
Glad you found something that works. Enjoy.
