nksaran
Nov 05, 2019Aspirant
My Orbi ring light turns pink and no internet
Hi, I bought this Orbi router 7 months back. It was working fine so far. But now the main Orbi router ring light turns pink and stays like that for ever till I reboot Orbi, this happned 2 times in 4...
- Nov 06, 2019
I upgraded the firmware to the latest one (V2.5.0.38) and I do not see the pink light issue from last night. If the ping light turns on again then I shall do factory reset, otherwis
Nov 05, 2019Guru - Experienced User
Have you powered OFF both ISP modem and RBR for 1 minuted, then back ON to see if this changes anything?
You might try a factory reset on the RBR and setup from scratch to see if FW has been updated recently.
nksaran
When this happned for the first time, I powered off both ISP modem and RBR for a minute and then powered back on both of them and Orbi was back online. Second time, I just powered off and powered on Orbi and Orbi was back online.
Is there a Orbi error or debug log that is stored somewhere in the router, which will give a clue for the pink light?
- FURRYe38Nov 05, 2019Guru - Experienced User
Ok. Has the LAN cable between the ISP modem and RBR been swapped out?
IF so, I would try a reset on the RBR and setup from scratch...
nksaran wrote:When this happned for the first time, I powered off both ISP modem and RBR for a minute and then powered back on both of them and Orbi was back online. Second time, I just powered off and powered on Orbi and Orbi was back online.
- AnonymousNov 05, 2019
FURRYe38 wrote:Ok. Has the LAN cable between the ISP modem and RBR been swapped out?
why aren't you asking about the firmware? - nksaranNov 05, 2019Aspirant
No, I have not yet swapped out the LAN cable between the ISP modem and RBR. I shall do it this eveing and see it solves the issue. As I am typing this message, Orbi light turned on pink again.
nksaran wrote:No, I have not yet swapped out the LAN cable between the ISP modem and RBR. I shall do it this eveing and see it solves the issue. As I am typing this message, Orbi light turned on pink again.
Firmware?
- CrimpOnNov 05, 2019Guru - Experienced User
nksaran wrote:Is there a Orbi error or debug log that is stored somewhere in the router, which will give a clue for the pink light?
"Logs" are a tricky subject. Orbi keeps a log file which can be accessed from the web interface (not the "app"). This log file is erased when the Orbi is turned off, so the user must log into the Orbi web interface, navigate to the Advanced Tab->Administration->Logs to see it. My Orbi has not "turned magenta" (close to pink, but that's what Netgear calls it), so I do not know if tis shows up in the log or not.
In addition, Orbi can create a "Debug Log". This is activated by browsing to http://<ip of orbi>/debug.htm, Enable LAN/WAN packet capture, and then Start Capture. I (personally) use this feature to capture some traffic for analysis. I found the "debug" file mysterious. I also have no idea if this file is erased when the Orbi is restarted. (Guess that could be tested.) I would connect to the Orbi debug.htm and "Save" the debug log before restarting the Orbi. Will this help? Beats the heck out of me.
People ask what the specific firmware number is because Netgear released an "update" about two weeks ago that has been widely reviled for causing problems when there were none before. (Maybe it "fixed some things", but the concensus appears to be that many users are happier going back to the previous firmware.) So, if "latest" means that you installed the new firmware, the recommendation is going to be, "GO BACK, and don't do this any more!"
Thanks for the info. I shall check the debug log to see I can find something. I shall also try to go back to the previous version of firmware to see, it solves this issue.
The 2.3.5.30 firmware has been out for about five months. If this problem started recently, the firmware is not likely to be the cause.
One thing that is often recommended is to do a "factory reset" on the Orbi. If you have not done extensive customizing of Orbi settings, this is relatively painless. (Some of us have spent hours assigning IP addresses to devices, customizing names, etc. etc. and dread having to do it all over again.)
