nksaran
Nov 05, 2019Aspirant
My Orbi ring light turns pink and no internet
Hi, I bought this Orbi router 7 months back. It was working fine so far. But now the main Orbi router ring light turns pink and stays like that for ever till I reboot Orbi, this happned 2 times in 4...
- Nov 06, 2019
I upgraded the firmware to the latest one (V2.5.0.38) and I do not see the pink light issue from last night. If the ping light turns on again then I shall do factory reset, otherwis
nksaran
Thanks. I shall do factory reset and see it resolves this issue. I have only customized the attached device names, other than this no additional config. So factory reset should not be a problem.
nksaran
Nov 06, 2019Aspirant
- FURRYe38Nov 06, 2019Guru - Experienced User
Good to hear. Hope it works well for you.
Please mark your thread as solved if you feel this works for you so others will know.
Enjoy. :smileywink:
nksaran wrote:I upgraded the firmware to the latest one (V2.5.0.38) and I do not see the pink light issue from last night. If the ping light turns on again then I shall do factory reset, otherwis
- Retired_MemberNov 06, 2019
I would keep an eye on it. I believe V2.5.0.38 has issues as well. Do a search in here.
Once your system is running OK, no more manual firmware updates.
FURRYe38 wrote:Ohters are having good operation past 5 days.
while many others have NOT...but I think you know that
