SilverSword58
Apr 19, 2020Follower
My Orbi Satellite won't connect to the Orbi Router
Hello, I recently purchased a Netgear Orbi RBR50 and was excited to set it up because my old router wasn't any good. We setup the router, and it worked smoothly. Then, we tried to hook up the satelli...
Retired_Member
Apr 20, 2020How long did the sat blink white before you gave up?
the firmware you have has known problems
leave the sat alone as in longer
if it does connect then go to downloads and look for an earlier firmware version
- AaronLTekApr 23, 2020Guide
I loaded Voxels' FW and after resetting the Sats and connecting them direct to the router it finally showed as Wired. Then I mived them back to thier locations and it still shows wired. I may be done with this buggy Netgear crap. I ordered ASUS it will be here tomorrow. I never had problems with ASUS gear... ran ASUS for 6 years prior to getting this Orbi.
Retired_Member wrote:How long did the sat blink white before you gave up?
