lolosyd
Oct 29, 2020Aspirant
My PC displays No Inernet when connected thru wifi to RBR50v2
RBR50 V2.5.2.4 PC OS: Windows 10 PC MBoard: MSI Gaming B450 Pro Carbon Max WIFI Motherboard (Intel Wireless-AC 9260 160mhz) My PC displays No Internet when connected thru wifi to RBR50v2 even ...
- Oct 29, 2020
Go to Intels web site directly.
Oct 29, 2020Guru - Experienced User
Be sure the wifi adapter drivers are updated from the Mfr of that adapter...
Have the Windows troubleshooting wizard reset the adapter...
lolosyd
Firmware of RBR50 v2.5.2.4
I did update the driver of the Wifi adapter thru windows and it said it has the most updated driver. How do you check with Manufacturer if windows has the most updated driver?
- FURRYe38Oct 29, 2020Guru - Experienced User
