walkerx
Feb 24, 2019Guide
MY Products all have red cross
I've noticed when I've logged into the netgear website and looked at my products, they all have a red cross under hardware, phone support, chat support and email support.
Does this mean that ev...
ekhalil
Feb 24, 2019Master
The Phone, Chat and Email support are only for the first 90 days. But I think you should have a green tick under hardware if you had the product less than one year.
I have the same situation and this is how my Netgear page look like now:
walkerx
Feb 24, 2019Guide
mine all have 3 stars
purchased june 2018
- ekhalilFeb 24, 2019Master
purchased june 2018
Then I think you need to contact NG regarding this. May be Blanca_O can kindly help with this? :)
- walkerxFeb 24, 2019Guide
ekhalil wrote:
purchased june 2018
Netgear won't let me contact them via email regarding this, so I've just contacted Amazon about it, advising of the issue with the single satellite and that according to netgear I have no warranty on the product, when there should be 2 years for UK users.
walkerx wrote:
..........Netgear won't let me contact them via email regarding this, so I've just contacted Amazon about it, advising of the issue with the single satellite and that according to netgear I have no warranty on the product, when there should be 2 years for UK users.
Ok, I hoep you will get some help from Amazon then.
By the way have tried the suggestions in the other post: :)
- Have you tried to factory reset the Satellite?
- Have you tried to connect the Ethernet backhaul to another LAN port on the Satellite?
