Michelli69
Apr 27, 2020Aspirant
My RBK14 router did not come with a password
My router did not come with a password, therefore use is unprotected. How do I create one?
Michelli69
Thanks for your reply. There was no Wifi password printed on the product label below the SSID, that space is blank.
Orbi was set up manually using the app. (barcode scanning wasn't recognized). Despite correct step-by-step manual setup, it still returned a "Router Not Found" message. Issues all around.
Apr 27, 2020Guru - Experienced User
See if you can connect using a wired connected PC to the router.
