Lboogie0208's avatar
Lboogie0208
Follower
Aug 31, 2020
My RBR 20 keeps going offline
Hi my Orbi RBR-20 switches time offline mode several times a day. I noticed it first when the pandemic started and I was working from home. I assumed it was an ISP issue since a ton more ppl were at home online. It took about a month but the issue stopped. It has since restarted a few weeks ago and can happen while on a call at work so it’s super inconvenient. I live in an apartment so my satellite is about 10 feet away from the router and I have it directly plugged into the Ethernet cable, no bridge or anything. Can someone please help?
1 Reply
  • FURRYe38's avatar
    10 feet is too close between the RBR and RBS. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
