Ghosthunterlife
Jan 03, 2023Aspirant
My RBR20 router giving intermittent internet
I am using a RBR20 Orbi router and it keeps dropping the signal or gives really poor speed. I have 580mps total for my wifi. I have spectrum and the said their modem isn’t the issue. I reboot it and it shows purple then blinking white then nothing after about 2 minutes. Help please. I’m pretty tech savvy but I’m stumped. Plug my nighthawk into same modem and it works fine.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Does the top ring LED turn on PINK when this happens?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings- GhosthunterlifeAspirantThank you so much for all this information. I will try tonight doing all this . Some I have done already with no improvement. House is 1700sq. Satellite is about 30ft away. I’m not sure how to change ip but I will try to figure that out. I will perform a full reset and new setup tonight. I really appreciate this since I’m out of the window for tech support.
Please leave feedback to the other question presented as well.
