Rafikix11
Mar 10, 2021Aspirant
My RBR50 will not connect to internet
My internet and router were working fine intil this morning when it wouldn't connect to internet. I tried resetting everything but it kept saying my password wasn't correct. Knowing this was wrong I t...
CrimpOn
Mar 10, 2021Guru - Experienced User
Rafikix11 wrote:
My internet and router were working fine intil this morning when it wouldn't connect to internet. I tried resetting everything but it kept saying my password wasn't correct. Knowing this was wrong I tried a factory reset. Now it will not connect to internet. I know it's not my modem because I have connected to internet via ethernet cable through my PS4. Anyone have any answers? Please advise.
After the factory reset:
- How are you attempting to configure the Orbi (web interface or Orbi "app")?
- What happens if, after the factory reset, the Orbi is cabled to the modem and turned on (nothing else, just turned on).
* Is there a sequence of "ring light" that match the ones expected?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean - Does the Orbi WiFi appear (the SSID printed on the product label)?
- Can a device connect to the Orbi WiFi using the SSID/password printed on the label?
Rafikix11
I was trying to use the orbi App to reconfigure.
I am getting a blinking white ring light.
It seems my devices will connect to router but no internet will come through.
On the Orbi app the setup seems to be going fine until it gets to the "checking internet connection..."
Looks like this
✅ Cables connected
❌Checking Internet Connection...
Looks like this
✅ Cables connected
- CrimpOnMar 11, 2021Guru - Experienced User
Looks like this
✅ Cables connected
❌Checking Internet Connection...Please describe that white ring light in more detail. I just now powered up an RBR50.
Immediately, the ring began to blink white in very close to a one second pattern (on...off...on...off...etc)
At 50 seconds, the ring began to pulse (slowly on....slowly off....slowly on....slowly off...etc.)
at 2:30 seconds, the ring light went out.
