russthau
Aug 22, 2021Aspirant
My RBS50 satellites experiencing high latency and packet loss
I have gigabit fiber coming into my house and have been using an RBR50 with two RBS50 satellites through the pandemic. With the latest firmware release I noticed that my network speeds are great. 100...
Aug 22, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update on the RBR?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- russthauAug 23, 2021Aspirant
I didn't do a reset to scratch. Just the power cycle after the firmware upgrade numerous times. What doesn't make sense is that my current set up worked perfectly for a year and a half. I did a firmware upgrade that caused issues and rolled it back. I think this might be the issue, but I don't know.
What I am trying to determine is how the set up stops working. Could it be hardware failure? The firmware? A new neighbor device? I live in San Francisco so there are WiFi access points all over the place.
- FURRYe38Aug 23, 2021Guru - Experienced User
I'd start by turning OFF RBS 1 at a time.
Then try 1 RBS online one at a time.
Swap RBS locations to see if problem follows.
