steph_
Dec 21, 2017Tutor
my stable orbi (router + 1 satellite) config
on the off chance that this might help somebody (and also in case i forget) since i was having connection issues here's my config (everything else was left to default). router:RBR50 satellite:RBS50...
- Dec 21, 2017
the config i posted was stable for a couple of days but since i noticed the fact that with WMM disabled it reduced the connection speed to 802.11a (54Mbps) i'm not impressed with the entire situation. factory reset everything and i'll be sending it back. this is actually the first time i've ever sent a purchase back. it's not worth wasting my time anymore. in it's current state with the current firmware the orbi isn't functionning as promised/advertised.
back to using my asus.
steph_
Dec 21, 2017Tutor
i just noticed with the above setup 5Ghz seems to be limited to 54Mbps (802.11a)...
quite frankly all this messing about is quite ridiculous. i was expecting more. since i already have an asus router i might switch over to ai-mesh once it's supported on my router.
steph_
Dec 21, 2017Tutor
