sccnyy23
Nov 06, 2018Tutor
MyNetgear Account - Change Email & merge accounts
Hello...I need to contact a moderator or a person who can help me merge two accounts. All my equipment is registered under one email address and I recently changed my primary email address but must ...
michaelkenward
Nov 07, 2018Guru - Experienced User
If you have access to the old account, have you tried "Deactivate Product" in MyNETGEAR?
Maybe you will then be able to add it to the new account.
- sccnyy23Nov 07, 2018Tutor
Michael - I thought about trying that, but did not want to lose the already loaded information. I will try to deactivate one of the products and see if I can add it to my new account.
I'll let you know if this works. Thanks.
- michaelkenwardNov 07, 2018Guru - Experienced User
Good luck!
The only other option I can think of is to ask a Netgear moderator to intervene.
Seems to work. I just transferred an old Powerline plug I had assigned to a different account.
It threw an error on the first attempt. But the second time it said "already registered". It was. To me.
So I tried deactivating a product from my original list of activated products. I was able to deactivate, but when I tried to add the products (S/N & date of purchase) to my new account, i got the following: "Something went wrong, Please contact support team". Herein lies the problem, there is no contact information for Netgear's support team nor do I know how to contact a moderator. Thanks for trying though.
