sccnyy23
Nov 06, 2018Tutor
MyNetgear Account - Change Email & merge accounts
Hello...I need to contact a moderator or a person who can help me merge two accounts. All my equipment is registered under one email address and I recently changed my primary email address but must ...
sccnyy23
Nov 07, 2018Tutor
Michael - I thought about trying that, but did not want to lose the already loaded information. I will try to deactivate one of the products and see if I can add it to my new account.
I'll let you know if this works. Thanks.
michaelkenward
Nov 07, 2018Guru - Experienced User
Good luck!
The only other option I can think of is to ask a Netgear moderator to intervene.
- michaelkenwardNov 07, 2018Guru - Experienced User
Seems to work. I just transferred an old Powerline plug I had assigned to a different account.
It threw an error on the first attempt. But the second time it said "already registered". It was. To me.
- sccnyy23Nov 07, 2018Tutor
I just tried registering the S/N & Date again about 10 different times and still no luck. Just keep getting "Something went wrong, Please contact support team." I have double checked to ensure that product is no longer activated under the old account, and it is not.
- FURRYe38Nov 07, 2018Guru - Experienced User
You'll need to phone in to NG support and have them help you with this. This is something the NG support needs to handle.
