Chadhetlet
Dec 10, 2016Guide
MyQ - Chamberlain compatibility
Having issues with my MyQ wifi garage door opener now that I have installed Orbi. MyQ app shows that door is up when it's really down or vice versa. App freaks out sometimes saying it's received too m...
- Dec 10, 2016
I am not having any issues, I am using the add on door sensors on my two doors. When my battery was running low in one of the sensors I had the issue like yours but once the battery was replaced it has been working perfectly.
Mikey94025
Dec 10, 2016Hero
Sorry, I haven't had any problems either with my MyQ. Perhaps also try moving the MyQ base somewhere else and closer to the Arlo base/satellite? Maybe it is having intermittent connectivity and losing open/close events.
Another possibility is that the MyQ is like the Nest cameras, which intermittently drop internet connectivity with Arlo. The workaround is to disable Implicit Beamforming. I have that disabled now and it might be why I'm not seeing problems with MyQ
