Chadhetlet
Dec 10, 2016Guide
MyQ - Chamberlain compatibility
Having issues with my MyQ wifi garage door opener now that I have installed Orbi. MyQ app shows that door is up when it's really down or vice versa. App freaks out sometimes saying it's received too m...
- Dec 10, 2016
I am not having any issues, I am using the add on door sensors on my two doors. When my battery was running low in one of the sensors I had the issue like yours but once the battery was replaced it has been working perfectly.
Chadhetlet
Dec 10, 2016Guide
Replaced battery and seems to be working fine again. Thanks!
- murchmanDec 10, 2016Apprentice
Wish the MyQ was smarter and could tell you the battery is dying instead of reporting the door is open when it's closed etc. As soon as I replied to your post I went to use my garage and the app was showing the door was open for 12 hours yet it was closed. Replaced the battery and all is good now.
- Retired_MemberDec 16, 2016
No issues with our Chamberlain garage doors. I have two, and both work fine.
- VE6CGXFeb 13, 2017Master
Is it possible to use long lasting Lithium battery?
