Chadhetlet
Dec 10, 2016Guide
MyQ - Chamberlain compatibility
Having issues with my MyQ wifi garage door opener now that I have installed Orbi. MyQ app shows that door is up when it's really down or vice versa. App freaks out sometimes saying it's received too m...
- Dec 10, 2016
I am not having any issues, I am using the add on door sensors on my two doors. When my battery was running low in one of the sensors I had the issue like yours but once the battery was replaced it has been working perfectly.
murchman
Dec 10, 2016Apprentice
Wish the MyQ was smarter and could tell you the battery is dying instead of reporting the door is open when it's closed etc. As soon as I replied to your post I went to use my garage and the app was showing the door was open for 12 hours yet it was closed. Replaced the battery and all is good now.
Retired_Member
Dec 16, 2016No issues with our Chamberlain garage doors. I have two, and both work fine.
