DrBSkull
Jan 30, 2019Guide
Mysterious Guest Network
I have an Orbi RBR50 and three RBS50 satellites and one RBS50Y as part of my network. I have an invisible/private GUEST Network setup which is NOT broadcasting an SSID. On several occasions when I ch...
- Jan 30, 2019
Yes I am using the guest network. The main reason I unchecked Broadcast SSID was while I was logging on to my guest network which is used for an outdoor wifi security and camera system and pool equipment as not to use my primary network was the first time I noticed the network appeared and it was unsecure, it actually show devices on my primary wifi network so I kept the name as not to have to reset all of my wifi security devices then created a hidden network with the same name.
If I uncheck Guest Network and just leave the name of the hidden network in the blank the guest network goes off line. I have not tried unchecking guest network and rebooting all four of my satellites. Trying that or a total factory reset might help the bigger problem is that this phantom or mystery network seems to come and go and it's unsecure as if sharing is turned on and it also sees my devices on my primary network. Currently I am not seeing it but it was there this morning. Rebooting the main router did make it go away but I'm afraid it will be back and my shared devices/files will be unsecure again. Very strange a network created by the Orbi which is called ORBI27-GUEST can see devices in the primary network.
DrBSkull
Jan 30, 2019Guide
Thank you for the reply Broadcast SSID is un-checked but I can not find a setting for "all radios"
Guest Network is checked, If I uncheck it I will loose my hidden network. You should only be able to connect to my guest network if you type in the name and Password / WPA2-PSK
Jan 30, 2019Guru - Experienced User
Are you using the Guest Network?
What happens if you uncheck Guest Network and reboot the router and satellite?
- DrBSkullJan 30, 2019Guide
- FURRYe38Jan 31, 2019Guru - Experienced User
I believe one of the satellites maybe out of sync with the base router.
I would power OFF a satellite, one at a time to see maybe where the SSID maybe coming from.
