WARNERP42
Jan 07, 2022Tutor
N300 WNR2000v3 Router Connecting to Roomba i3
I recently purchased an iRobot Roomba i3 but have been unable to set it up due to Wi-Fi connection issues. I run through the Roomba set up, but when it gets to the point of connecting to Wi-Fi I get ...
- Jan 08, 2022
Arris SBB200? Do you mean SB8200? There isn't an SBB
If so, you're bottleneck is big time on that router. Its a old base model N300 devices with only 10/100mbps connections. Its not gigabit either. An upgrade in the future might be a good plan.
What security are you using on the router?
Jan 08, 2022Guru - Experienced User
The WNR2000 doesn't have 5ghz.
What firmware is on it?
What modem/gateway is it connected to?
- WARNERP42Jan 08, 2022Tutor
Thank you! Here are the answers to your questions:
That is interesting to learn.
It is on Firmware v1.1.2.18.
It is connected to an Arris SURFboard SBB200 cable modem.
- plemansJan 08, 2022Guru - Experienced User
- WARNERP42Jan 10, 2022Tutor
Thanks for your help on this thread. I ended up purchasing a new NETGEAR Nighthawk AC1900 R7000 Wi-Fi Router. Still trying to resolve the iRobot Roomba i3 issue however. NETGEAR technical support did not have any suggestions when I called them.
