WARNERP42
Jan 07, 2022Tutor
N300 WNR2000v3 Router Connecting to Roomba i3
I recently purchased an iRobot Roomba i3 but have been unable to set it up due to Wi-Fi connection issues. I run through the Roomba set up, but when it gets to the point of connecting to Wi-Fi I get ...
- Jan 08, 2022
Arris SBB200? Do you mean SB8200? There isn't an SBB
If so, you're bottleneck is big time on that router. Its a old base model N300 devices with only 10/100mbps connections. Its not gigabit either. An upgrade in the future might be a good plan.
What security are you using on the router?
Mikey94025
Jan 07, 2022Hero
You posted in the wrong product group. I believe you are looking for: https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
WARNERP42
Jan 08, 2022Tutor
Thanks! I just posted this in that product group as well.
