WARNERP42
Jan 07, 2022Tutor
N300 WNR2000v3 Router Connecting to Roomba i3
I recently purchased an iRobot Roomba i3 but have been unable to set it up due to Wi-Fi connection issues. I run through the Roomba set up, but when it gets to the point of connecting to Wi-Fi I get ...
- Jan 08, 2022
Arris SBB200? Do you mean SB8200? There isn't an SBB
If so, you're bottleneck is big time on that router. Its a old base model N300 devices with only 10/100mbps connections. Its not gigabit either. An upgrade in the future might be a good plan.
What security are you using on the router?
Jan 10, 2022Guru - Experienced User
let me know how it does with no security. I played with a roomba when it first came out that struggled until it updated its software.
WARNERP42
Jan 12, 2022Tutor
Thanks everyone who weighed in on this thread. After 3+ weeks of trying to resolve this issue with the Roomba, I'm giving up and returning it unless their tech support gets back to me ASAP. I even tried opening up the guest Wi-Fi connection and nothing different happened - the robot wouldn't connect. :-(
- CrimpOnJan 12, 2022Guru - Experienced User
I know two people who have a Eufy vacuum on their original Netgear Orbi (ac). Neither mentioned anything about it being difficult to connect.
