JGold's avatar
JGold
Tutor
Feb 04, 2020
Named DNS with dynamic IP address - Orbi
I'm using the Orbi running firmware version 2.3.5.30.   I'm trying to set up my router to use a specific DNS server (OpenDNS), not automatically provided by my ISP. In the admin interface, the "Use...
  • JGold's avatar
    Feb 04, 2020
    Problem solved.
    You need to disable Circle (Advanced->Security->Parental Controls).  Then you can set your specific DNS with automatic IP address. Once that's set up, you can go back and re-enable Cicle.  The DNS / IP settings will remain.  I don't know why Cicle would force that interaction, but the resolution is easy.
