dingzheng
Aug 03, 2018Tutor
Nas and orbi
I used to use tp link ac2800, for half year, it has alot of issues such as it has two wifi names i had to change between 2.4 and 5 g my self, and the 5g always jammed, and so on, however, i never had...
Aug 03, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- dingzhengAug 03, 2018Tutor
Used kasperskey as fw and if you were asking about the fw on router, i did not change anything at all.
The house is not big, and the strainght distance between two of them is definitely less than 10 foot, and the single given was good.
Did not think i need to set up so many other things, but, thanks
