deltaboy
Dec 06, 2019Aspirant
NAS keeps disconnecting
i have a WD MyCloud EX2 Ultra and ever since switching to the Orbi system, my NAS keeps disconnecting... its wired directly to the RBR20. my previous D-Link setup was fine and i did not make any chan...
Dec 06, 2019Guru - Experienced User
What do you mean by disconnecting? Do you loose access to it's web page?
What is the Mfr and model# of the NAS?
Have you set up a IP address reservation for the NAS ON the router?
deltaboy
Orbi Router Firmware Version V2.3.5.36
MyCloudEX2Ultra 2-Bay NAS by Western Digital
yes FURRYe38 my NAS has an IP reservation... i mapped the drive to my iMac, but it will dissapear at times and i have to bring it back my mounting again.
- FURRYe38Dec 06, 2019Guru - Experienced User
Is there an IP address reservation for the mac as well?
Is your Mac wired or wireless?
Does this happen with other PCs or Macs?
Something to try differently, set a new IP address pool size on the RBR. Say 192.168.1.100 thru .200.Remove the IP address reservation for the NAS from the RBR.
Go in and set a Static IP address ON the NAS using it's web page, say 192.168.1.2. The static can be anything, just outside of the IP address Pool. Can't be with in it.
