ssandheinrich
Dec 30, 2018Aspirant
NAS on the Orbi
I purchased the RBR50 tri-band mesh router for our home from Costco. I noticed that there are USB ports on the back of the access points. Can you connect a drive for a network attached storage? I d...
Dec 30, 2018Guru - Experienced User
Not at this time. NG only seems to support USB printers connected to the USB port.
- ssandheinrichDec 30, 2018Aspirant
Any benefit to USB attached printer v.s. wireless connections to the printer? Thanks for the info.
- FURRYe38Dec 30, 2018Guru - Experienced User
USB would not take up any wifi bandwidth. If your not doing alot of printing you could use USB. Wireless you could allow wifi devices to connect directly to the printer.
