trigger_cut
Aug 01, 2023Aspirant
NAS visible to only some computers on network
I’m unable to access my Synology NAS drive from three computers on our home network. I cannot tell if the problem lies with the Synology NAS, our router, or the computers in question. Here is the...
Aug 01, 2023Guru - Experienced User
Is seem you have a router infront of the RBR router if the RBR is currently using 10.0.0.x: This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
What happens if you turn OFF the RBS and connect everything to the RBR?
trigger_cut
> What Firmware version is currently loaded?
V2.7.4.24
> What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
The router is from a German ISP, Pyür. Model number: "CH746CE"
I have disabled the Wifi networks that ISP router/modem produces. However, I don't believe I changed any other settings on the modem.
Any advice on how to perform (1) or (2) that you recommended?
- FURRYe38Aug 01, 2023Guru - Experienced User
Might consider updating FW:
Contact the ISP on how to configure there hardware. I'd try option #2 first.
- trigger_cutAug 01, 2023Aspirant
It doesn't look like any firmware upgrades are available for this model.
Updates are here:
