trigger_cut
Aug 01, 2023Aspirant
NAS visible to only some computers on network
I’m unable to access my Synology NAS drive from three computers on our home network. I cannot tell if the problem lies with the Synology NAS, our router, or the computers in question. Here is the...
trigger_cut
> What Firmware version is currently loaded?
V2.7.4.24
> What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
The router is from a German ISP, Pyür. Model number: "CH746CE"
I have disabled the Wifi networks that ISP router/modem produces. However, I don't believe I changed any other settings on the modem.
Any advice on how to perform (1) or (2) that you recommended?
Aug 01, 2023Guru - Experienced User
Might consider updating FW:
Contact the ISP on how to configure there hardware. I'd try option #2 first.
- trigger_cutAug 01, 2023Aspirant
It doesn't look like any firmware upgrades are available for this model.
- FURRYe38Aug 01, 2023Guru - Experienced User
Updates are here:
- trigger_cutAug 04, 2023Aspirant
The ISP has now switched their router/modem into pure bridge mode. However, Orbi is still on 10.0.0.x. The internet port has changed from 192.168.0.5 to 100.90.1.37. So there must still be some Double NAT going on. I also can't seem to find the login for the ISP's router.
What do I need to do to get rid of the double NAT for good? Complete reset of Orbi so it stops with the 10.0.0.x thing?
