Xaunaught
Mar 21, 2020Tutor
NAT issue for switch / in general - RBR50
Hi all, I have been having NAT issues for the past 4 months since I moved house. I have a public IP address so I believe that means it isn't double NAT? My setup is: Main orbi ethernet into ps4...
- Apr 15, 2020
It ended up being an issue on my ISPs end. I contacted them and they were able to fix it instantly.
It isn't a fun solution but it was the only thing that fixed it.
Xaunaught
Mar 21, 2020Tutor
CrimpOn Sorry I realise that was confusing. Two Nintendo Switchs, the gaming console. I forgot that a switch is actually a networking thing as well, my bad.
The Orbi isn't connected to a modem. It is connect to an NBN system. A thing we have here in Australia that is built into the home. This: https://support.belong.com.au/nbn/order/what-is-the-difference-between-a-nbn-utility-box-and-a-nbn-connection-box
CrimpOn
Mar 21, 2020Guru - Experienced User
Wow, fiber. Maybe more research into Animal Crossing is in order:
- XaunaughtMar 21, 2020Tutor
So putting in those TCP numbers didn't help
I am only able to set UDP between 13000-65534 as anything under 13000 says it is in use even though nothing enabled says it is using it from what I can see
and 65535 says it is an invalid range.
