Xaunaught
Mar 21, 2020Tutor
NAT issue for switch / in general - RBR50
Hi all, I have been having NAT issues for the past 4 months since I moved house. I have a public IP address so I believe that means it isn't double NAT? My setup is: Main orbi ethernet into ps4...
- Apr 15, 2020
It ended up being an issue on my ISPs end. I contacted them and they were able to fix it instantly.
It isn't a fun solution but it was the only thing that fixed it.
kayros
Apr 15, 2020Aspirant
I'm having the same exact problem. Did you ever find a solution?
- XaunaughtApr 15, 2020Tutor
It isn't a fun solution but it was the only thing that fixed it.- FURRYe38Apr 16, 2020Guru - Experienced User
Glad it was an easy fix. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
- xaznweirdo26Apr 19, 2020Aspirant
I am having the same exact problem! I was wondering if you knew what your ISP did on their end to help out?
I tried calling my ISP and they stated that the issue is with my router and port forwarding...
- FURRYe38Apr 20, 2020Guru - Experienced User
xaznweirdo26 wrote:I am having the same exact problem! I was wondering if you knew what your ISP did on their end to help out?
