go_robot_go
May 25, 2017Initiate
NAT loopback supported by Orbi?
I'm currently a user of the eero mesh wi-fi system, and I've discovered that it doesn't support NAT loopback (in other words, from inside my home network, I cannot reach local resources by using an e...
DarrenM
Jun 08, 2017Sr. NETGEAR Moderator
Unable to access local resources is a confirmed bug in latest FW. Will be fixed in next official firmware release.
DarrenM
- peteytestingJun 09, 2017Hero
thanks for the confirm darren , was unaware of this as i tested it prior and was working fine
pete
- go_robot_goJun 09, 2017Initiate
Darren, thanks for the response. Is there a timeline on the resolution for this bug, or could you update this thread when the fix is released? I'm eager to replace my wonky eero setup with Orbi, but I'm hesitant to commit to a puchase until I know that this is fixed.
