go_robot_go
May 25, 2017Initiate
NAT loopback supported by Orbi?
I'm currently a user of the eero mesh wi-fi system, and I've discovered that it doesn't support NAT loopback (in other words, from inside my home network, I cannot reach local resources by using an e...
clifgriffin
Oct 13, 2017Aspirant
Any updates on this? It's been quite a few months since this was posted and I'm still not able to connect to local resources with an external domain name while connected to the Orbi network.
Retired_Member
Oct 13, 2017It's been better but intermittent since 1.11.x.
- clifgriffinOct 13, 2017AspirantHmm, it just spins for me. Any configuration requirements? I'm on the latest firmware. (2.074 I think)
- aazOct 15, 2017Virtuoso
It's working for me on 2.0.0.74, have you guys enabled port forwarding to the devices that you expect to connect to from outside? And have you tested that it works from the internet?
