go_robot_go
May 25, 2017Initiate
NAT loopback supported by Orbi?
I'm currently a user of the eero mesh wi-fi system, and I've discovered that it doesn't support NAT loopback (in other words, from inside my home network, I cannot reach local resources by using an e...
Retired_Member
Oct 13, 2017It's been better but intermittent since 1.11.x.
clifgriffin
Oct 13, 2017Aspirant
Hmm, it just spins for me. Any configuration requirements? I'm on the latest firmware. (2.074 I think)
- aazOct 15, 2017Virtuoso
It's working for me on 2.0.0.74, have you guys enabled port forwarding to the devices that you expect to connect to from outside? And have you tested that it works from the internet?
