Sennevds
May 29, 2019Aspirant
Nat loopback
Hi, I've found a thread about nat loopback but no answer. It looks like nat loopback is not working. I've configured port forwarding which is working perfect when using data on phone of from anot...
CrimpOn
May 30, 2019Guru - Experienced User
Sennevds wrote:It looks like nat loopback is not working. I've configured port forwarding which is working perfect when using data on phone of from another network.
When i'm trying to use the same dns name and port from within my home network I can't connect to my webapp.
Is this a known issue(or feature) or do I have to change some settings?
Netgear has a web site (dated August, 2018) showing which router models support NAT loopback:
https://kb.netgear.com/000049578/NETGEAR-Router-support-for-NAT-Loopback
None of the Orbi models appear on the list. Since Orbi is based on OpenWRT and the Nighthawk line is not, my guess is that Orbi does not support NAT loopback.
Sennevds
May 30, 2019Aspirant
Owkey that sucks. Going to search for another solution. Thanks for the answer.
- FURRYe38May 30, 2019Guru - Experienced User
Can find you a router that supports loopback then disable it's WiFi on that router and configure Orbi for AP mode and use as your main wireless system.
Good Luck.
