Sennevds
May 29, 2019Aspirant
Nat loopback
Hi, I've found a thread about nat loopback but no answer. It looks like nat loopback is not working. I've configured port forwarding which is working perfect when using data on phone of from anot...
Sennevds
May 30, 2019Aspirant
Owkey that sucks. Going to search for another solution. Thanks for the answer.
May 30, 2019Guru - Experienced User
Can find you a router that supports loopback then disable it's WiFi on that router and configure Orbi for AP mode and use as your main wireless system.
Good Luck.
