jkb24212
Jul 21, 2020Aspirant
NAT Protection with Orbi Mesh
From the beginning, routers provided protection from the outside intruders using NAT, but is an Orbi mesh really providing this? Since it’s not a router in the conventional sense, has the protection b...
Jul 21, 2020Guru - Experienced User
ALL home class routers have NAT. You it's one design that has to be there or "routers" won't work.
Orbi and NAT Filter options, Secure and OPEN. Secure is set by default.
NAT is only for translation of traffic from the LAN to WAN and WAN to LAN only. Doesn't provide any support for keeping hackers or malware out of ones computer. Some of that is handled by the firewall.
Gateway modems have built in routers FYI. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
