BigDingus
Apr 22, 2022Tutor
NAT Stopping FTP
Hi folks. I've been trying to use FTP downloads to my PC but can't get the data connection to work. It was working fine when I had a DGND3700 but when I changed to Orbi the problems started. Throu...
- Apr 30, 2022Just an update.
After managing to borrow another router I found it wasn’t the NAT that was causing the problem.
I did however find it was due to some bad coding in my server.
Thanks for the help
Apr 22, 2022Guru - Experienced User
What orbi model system do you have?
