webdolphin's avatar
webdolphin
Follower
May 29, 2021
NAT Subnetmask
Maybe somebody can help me.. I don't know, if the orbi can do what I would need. I have a public IP Adress from my provider (which I use for my server/Exchange Server) On this IP-Adress I have a su...
  • FURRYe38's avatar
    May 29, 2021
    I don't believe Orbi supports that. Only NAT configuration is NAT Filter seen under Advanced tab, setup, wan setup. This changed the NAT kind feature on Orbi systems. Port Address Restricted Cone and Full Cone NAT.
