CN_
Oct 17, 2022Aspirant
NBK750 Connector Types
Can anyone tell me what the connector type is that connects the external (and internal) antennas to the Orbi's modem? (inside of the Orbi) Specifically looking at the external antenna connectors...
Oct 17, 2022Guru - Experienced User
Looks like SMA connectors on the NBR unit:
https://www.downloads.netgear.com/files/GDC/NBK752/NBK752_NA_DS.pdf
CN_
Yes, on the outside. If you read my post - I want to know the connector type at the other end of those SMA connectors, inside of the Orbi (Note: it is not SMA).
- FURRYe38Oct 17, 2022Guru - Experienced User
Well, not sure about that. Nobody opens up the case and goes inside to see what the internals are. Doing that would void warranty and could damage the unit. Would be no user need to do anything from a internal use standpoint.
You might try looking at the FCC web site to see if they show the NBK750 in there list and generally, they have internal pictures.
I have seen some pictures and some are a quick disconnect kind of tiny wired connector that connects to the board from the antenna.
Possible one of these: https://www.data-alliance.net/mhf-series-mhf1-mhf3-mhf4/
