mickoe
Oct 18, 2022Follower
NBK752 no Firmware support at all?
Hi, I am just wondering if there's any firmware update or support for this system at all from Netgear or if it's a lost system. The stability of the system is "ok", but not above average. In contras...
Oct 18, 2022Guru - Experienced User
They don't tell us when firmware releases are or whats being worked on.
But you will see releases take longer with those devices that aren't just routers. The modem/router combo devices (or lte devices) do have extra coding/work on them so take longer.
