joedennis
Nov 11, 2018Follower
NBN HFC connection slow speeds
I recently ordered an NBN HFC 100/40mbps connection from a smaller RSP in Sydney. I am running my Orbi directly into the NBN NTD device and have set up VLAN tagging as per retail providers instructio...
jannico
Nov 11, 2018Aspirant
I'm on TPG HFC NBN50 plan and with standard setup on Orbi just tested my speed and got 40/15 on speed.com and 28/19 on speedof.me. Did you get a router from ISP that can try instead of the Orbi?
- BarryTregNov 12, 2018Apprentice
I'm on AussieBB 100/40 HFC NBN. Before I recently moved away from Orbi, I was getting 95-ish speeds on download. Wireless on 5Ghz also up at that speed as well. So Orbi definately supports those sorts of download speed on HFC.
With Orbi, I found there was quite a bit of trial an error. Many options to go through. First thing I'd prob do is plug direct onto the NBN box and see if the speed is OK there on one device. If OK, then try with ORbi , no satellite. Then add satellite.... Good luck!
