joedennis
Nov 11, 2018Follower
NBN HFC connection slow speeds
I recently ordered an NBN HFC 100/40mbps connection from a smaller RSP in Sydney. I am running my Orbi directly into the NBN NTD device and have set up VLAN tagging as per retail providers instructio...
Nov 12, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
