Jeff837
Jan 07, 2018Initiate
Nearby device will not connect to satellite
I have the main router on Floor 1, and the satellite on Floor 2, which is 5 feet from the front door. I have installed a Ring Doorbell on the front door. However, it only connects directly to the r...
Retired_Member
Apr 06, 2018I have the same problem with my Skybell doorbell, if I update the firmware or restart the router, the doorbell will always reconnect on the router, I need to do an soft reset on doorbell for force the device to connect on the satellite, a method for to force specific device to connected on the router or satellite is missing and should be a good thing
- FURRYe38Apr 06, 2018Guru - Experienced User
maybe the Doorbell maybe choosing the "better" signal and thinks the router signal is better than the Satellite.
What version of FW are you using?
Retired_Member wrote:I have the same problem with my Skybell doorbell, if I update the firmware or restart the router, the doorbell will always reconnect on the router, I need to do an soft reset on doorbell for force the device to connect on the satellite, a method for to force specific device to connected on the router or satellite is missing and should be a good thing
- GlennrApr 06, 2018Aspirant
The problem is two fold. One, Orbi is NOT a mesh nework and two, Netgear has not figured out how to show the correct connections. There was a firmware that was supposed to fix it but it was "recalled". The latest 2.1.3.4 still has the connection display problem. One way to test this is to connect something by cable to a port on the satelite. If that shows as connected to the main Oribi you will have the answer.
- Retired_MemberApr 06, 2018
My Skybell application show me signal quality, when connect on router signal is poor and good on satellite also for me the Orbi app show properly where my device is attached.
Never, when connected on router the signal is poor and on satellite is good
- st_shawApr 06, 2018Master
This happens because the Orbi router always comes up before the satellites upon a reboot or power cycle of the Orbi system. Devices that do not roam, such as OSX laptops or desktops and many IP cameras, will connect to the first device they see and never switch. There is no way to force devices to connect to a given Orbi unit, so to connect to the nearest Orbi, you may need to power cycle your non-roaming devices after every time Orbi reboots.
Some non-roaming devices like doorbells are not easily power cycled. I wonder if power cycling just the router might do it?
- Sal364Sep 17, 2018InitiateI’m 30 feet from the router and 5 ft from the satellite and FaceTime and other programs say poor connection. All firmware is up to date. This is happening with android iPad and iphonex
- GlennrSep 17, 2018Aspirant
Find a free phone app for signal strength for one of your devices. It might help you find the issue.
- FURRYe38Sep 18, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
