Jeff837
Jan 07, 2018Initiate
Nearby device will not connect to satellite
I have the main router on Floor 1, and the satellite on Floor 2, which is 5 feet from the front door. I have installed a Ring Doorbell on the front door. However, it only connects directly to the r...
Apr 06, 2018Guru - Experienced User
Did you reset both router and satellite after updating then setup from scratch?
Anonymous
Apr 06, 2018Any reason to setup at scratch after an firmware upgrade?
