Jeff837
Jan 07, 2018Initiate
Nearby device will not connect to satellite
I have the main router on Floor 1, and the satellite on Floor 2, which is 5 feet from the front door. I have installed a Ring Doorbell on the front door. However, it only connects directly to the r...
Anonymous
Apr 06, 2018I have the same problem with my Skybell doorbell, if I update the firmware or restart the router, the doorbell will always reconnect on the router, I need to do an soft reset on doorbell for force the device to connect on the satellite, a method for to force specific device to connected on the router or satellite is missing and should be a good thing
st_shaw
Apr 06, 2018Master
This happens because the Orbi router always comes up before the satellites upon a reboot or power cycle of the Orbi system. Devices that do not roam, such as OSX laptops or desktops and many IP cameras, will connect to the first device they see and never switch. There is no way to force devices to connect to a given Orbi unit, so to connect to the nearest Orbi, you may need to power cycle your non-roaming devices after every time Orbi reboots.
- GlennrApr 06, 2018Aspirant
Some non-roaming devices like doorbells are not easily power cycled. I wonder if power cycling just the router might do it?
