Jeff837
Jan 07, 2018Initiate
Nearby device will not connect to satellite
I have the main router on Floor 1, and the satellite on Floor 2, which is 5 feet from the front door. I have installed a Ring Doorbell on the front door. However, it only connects directly to the r...
Retired_Member
Apr 06, 2018I have the same problem with my Skybell doorbell, if I update the firmware or restart the router, the doorbell will always reconnect on the router, I need to do an soft reset on doorbell for force the device to connect on the satellite, a method for to force specific device to connected on the router or satellite is missing and should be a good thing
Sal364
Sep 17, 2018Initiate
I’m 30 feet from the router and 5 ft from the satellite and FaceTime and other programs say poor connection. All firmware is up to date. This is happening with android iPad and iphonex
- GlennrSep 17, 2018Aspirant
Find a free phone app for signal strength for one of your devices. It might help you find the issue.
- FURRYe38Sep 18, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
