Jeff837
Jan 07, 2018Initiate
Nearby device will not connect to satellite
I have the main router on Floor 1, and the satellite on Floor 2, which is 5 feet from the front door. I have installed a Ring Doorbell on the front door. However, it only connects directly to the r...
Chris1984
Feb 25, 2019Tutor
I am expecting the same issue!
Feb 25, 2019Guru - Experienced User
What are you expecting?
A little more information will be needed here.
- Chris1984Feb 25, 2019Tutor
Basically i have a nest door bell next to my orbi satellite (it is only 2 meters away) and the nest camera is connecting to my main orbi router that is situated over 10m away and is onanother floor. Moreover the connection is poor it is 30%.
Thanks
Chris
- FURRYe38Feb 25, 2019Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Thanks
Chris
So basically the orbi is connected to my ISP and the ISP modem i steh Technicolor TG789vac v2 - http://www.resqnet.co.uk/wp-content/uploads/2016/02/TG789vac-v2-Set-up-and-user-guide.pdf
The conncction between the orbi router and satalite is marked as good on the orbi app. so i guess that there is no issue between the orbi devices.
The neighbours wifi is wery weak signal.
WPA is - WPA2-PSK [AES]
2.4 ghz is on chanel 6
5 ghz is on chanel 40
Beamforming and MIMO are enabled .
