Raee
Jan 28, 2021Aspirant
nearby device won't connect to satellite - Do not mix RBR50 & RBS20
FYI rbr50 rbs50 & 2 x rbs20 (rbk43 kit) satellites No matter what power recycling, hard wired or wifi, etc etc no connection it seems that my iphone could smell the RBR50 and so it would ...
Jan 28, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Raee
Why? The object of the game is maximum coverage in a concrete home, btw latest FW.
Hence the addition of the 2 extra satellites.
- RaeeJan 28, 2021Aspirant
Also we can get 500mbs down and 20 mbs up on wifi on the RBR 50
- FURRYe38Jan 28, 2021Guru - Experienced User
Why? "concrete home" this would be your problem. Concrete and steel will impact signal travel and performance. Your devices maybe picking the RBR since they seem to feel the RBR signal is better than the RBS. It's to the wifi devices to pick and choose where they connected too. Orbi doesn't do this.
- vajimJan 28, 2021Master
FURRYe38 wrote:Why? "concrete home" this would be your problem. Concrete and steel will impact signal travel and performance. Your devices maybe picking the RBR since they seem to feel the RBR signal is better than the RBS. It's to the wifi devices to pick and choose where they connected too. Orbi doesn't do this.
Not true
The router is the decision maker
So what that means is that the system does not work with a MIXED satelite as quoted... This will be my last post
