Raee
Jan 28, 2021Aspirant
nearby device won't connect to satellite - Do not mix RBR50 & RBS20
FYI rbr50 rbs50 & 2 x rbs20 (rbk43 kit) satellites No matter what power recycling, hard wired or wifi, etc etc no connection it seems that my iphone could smell the RBR50 and so it would ...
DeanB1452
Jan 29, 2021Apprentice
I live in a 1600 sq. ft., 3 bedroom, wood framed, single story house. Each satellite is about 30 feet from the router in each corner room of the house. Implicit Beamforming, MU-MIMO, and Fast Roaming are enabled.
Jan 29, 2021Guru - Experienced User
For that size of home, if you have the RBR and 2 or 3 RBS, that maybe having too much wifi signals. For 1600 sq ft 1 RBR and 1 RBS would be only needed. I have a 5000sq ft phone and use only 1 RBR and 1 RBS most of the time and coverage is good all around.
DeanB1452 wrote:I live in a 1600 sq. ft., 3 bedroom, wood framed, single story house. Each satellite is about 30 feet from the router in each corner room of the house. Implicit Beamforming, MU-MIMO, and Fast Roaming are enabled.
- vajimJan 29, 2021Master
FURRYe38 wrote:For that size of home, if you have the RBR and 2 or 3 RBS, that maybe having too much wifi signals. For 1600 sq ft 1 RBR and 1 RBS would be only needed. I have a 5000sq ft phone and use only 1 RBR and 1 RBS most of the time and coverage is good all around.
copy paste not working?
5000sq ft phone.....that's a big phone
but we got ya...you meant to say 5000sq ft home...or my home is 32% bigger than yours
- RaeeJan 29, 2021Aspirant
My issue is now solved, NETGEAR's Tech support recommended to return the kit, the matter is closed and the RBK43 has been returned.
- DeanB1452Jan 29, 2021Apprentice
Originally I had just the RBK53 and some of the Ring cameras around the perimiter of the house had weak signals. Added the RBR20 to the master bedroom to boost the signal to the Ring Camera in one corner of the backyard and moved one satellite to the other corner of the house to provide a wired connection to a desktop computer in my child's room as well as the rest of the backyard which was having dead zones before I repositioned them. Basically a router/satellite in each corner of the house to cover my 6200sq ft lot. Haven't had any issues with the Ring devices ever since. Haven't had any issues roaming around the house or backyard streaming music on my iphone with fast roaming enabled too.
DeanB1452 wrote:Originally I had just the RBK53 and some of the Ring cameras around the perimiter of the house had weak signals. Added the RBR20 to the master bedroom to boost the signal to the Ring Camera in one corner of the backyard and moved one satellite to the other corner of the house to provide a wired connection to a desktop computer in my child's room as well as the rest of the backyard which was having dead zones before I repositioned them. Basically a router/satellite in each corner of the house to cover my 6200sq ft lot. Haven't had any issues with the Ring devices ever since. Haven't had any issues roaming around the house or backyard streaming music on my iphone with fast roaming enabled too.
Nice, so check those two options off the list
