Sierra8824
Dec 11, 2019Aspirant
Neato d6
The Orbi does not allow the access point WiFi for neato to be recognized. I’m not super savvy but I never had this “discovery” problem before we changed internet carriers
CrimpOn
Dec 11, 2019Guru - Experienced User
You are probably following the setup instructions:
You mention recently changing internet carriers. It could be that the previous carrier supplies "only a modem" and the new carrier supplied a "modem/router". While this ordinarily does not cause a problem, in specific instances it can.
What is the brand and model number of the current internet supplier equipment?
Is the Orbi operating in "router" or "access point" mode?
Sierra8824
Dec 12, 2019Aspirant
And the Orby is my router. And I bought a surfboard modem. My Alexa hooked up easily with the Amazon access point appearing in my Wi-Fi options. Does this seem to mean that it is a neato problem and not a router problem?
- CrimpOnDec 12, 2019Guru - Experienced User
Sierra8824 wrote:
And the Orby is my router. And I bought a surfboard modem.Can you please provide the specific model number of the Surfboard modem?
Thanks
- Sierra8824Dec 14, 2019AspirantArris surfboard SB6190
- CrimpOnDec 14, 2019Guru - Experienced User
Thanks for providing the model number, which confirms that your modem is "only a modem". Therefore, you have only one router, the Orbi.
So, you put the vacuum in "Pairing Mode", the light blinks, you get to step C of the instructions and the Neato D6 WiFi does not show on the list of WiFi networks?
You are doing this on an Apple or Android device?
