ken800
Nov 26, 2019Aspirant
Need 2.4ghz backhaul but want to use my orbi rbk 50 - orbi as A/P and still use satellite?
I have an RBK 50 and satellite setup. I live out in the woods and my only internet option as a 50' line of sight tower. It is ugly as sin so I have it over behind the barn and the feed from the dis...
Nov 26, 2019Guru - Experienced User
Or you could get a point to point system. They allow much further broadcast of wifi and you'll be able to run the cabling into the house to avoid having to penetrate through the steel/veneer.
ken800
Thanks all. I think I may just bury a cable and the problem is sovled. I can return my Orbi as my house is small and use my current Linksys router which is a higher end model anyway.
- FURRYe38Nov 26, 2019Guru - Experienced User
:smileywink:
- CrimpOnNov 26, 2019Guru - Experienced User
It might be useful to make a cost comparison between burying 150' of ethernet cable and deploying an ethernet bridge. Direct burial cable will cost about $100. Then there is the cost & complexity of burying it and keeping it from being disturbed. A pair of outdoor wireless bridges runs from $50 to $200 depending on brand and speed. And, of course, if an electrical circuit or coax runs between the two buildings, there are other options.
